I'm assuming 1080p? If so, yeah, he's right. Your GPU won't be running at 100% most of the time.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775064
It's a good card, and it might be bottlenecked slightly by the processor. It's not a good platform, however if you already have it and you're on a budget it's not the absolute worst thing in the world.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775070
a GTX 880 ;)
but seriously, a 900 series maybe
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775078
Your better off getting a better CPU, the GTX 1060 6GB is a great card, and that FX CPU won't be putting out everything you want. Best bet will be to try and go to the Ryzen platform with something like the Ryzen 1600 if you can't afford to go for a Ryzen 2600, then get 8-16GB of DDR4 RAM, and a B350 or B450 motherboard depending on if you get the Ryzen 1600 or 2600.
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775146
he has everything except the GPU and HDD. 32GB of RAM in fact. so, at this point he is a little bit invested in this FX system.
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775192
Misread it, the 1050 TI is a better card to get. if the OP plans to update his CPU in the next 1-2 years.
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11775367
As far as i know he plans to keep it for a while. Next time i have access to a 1060, im going to see what settings are best for his system (system i am referencing is FX-6300) so i think it only goes up from there.
https://linustechtips.com/topic/974232-building-a-pc/#findComment-11776162
