so guys this is what i just bought
i5 8400
1060 6 gb o6g
8gb ddr4 2666mhz
b360m-k
550w evga 80 pluz bronze psu
1tb hdd
120 kingston ssd
22" 1080p monitor
case xigmatek hawthorn
So about the stock cooler on the i5 , im asking if i should replace it , i wouldnot be doing any overclocking on the cpu/gpu
https://linustechtips.com/topic/974091-cooler-i5-8400/
No, the stock one should be fine for this CPU.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11773913
good thing you can't then, with a non-k CPU
stock cooler is perfectly fine, and I've seen some people put a round sticker on the middle over the Intel sticker to make it look extra stylish, since that stupid blue iridescent sticker doesn't go with anything.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11773933
2 minutes ago, Bigman397 said:
the stock heatsink is barely sufficient for stock clocks
It is once you replace the thermal paste with something a bit better.
زندگی از چراغ
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11773938
Stock cooler is a crap - it becomes loud very soon. Of course there are people who says "I don't care about noise" - but they're mostly never uses silent pc.
But if you asking for temperatures - sure, that cooler is sell with that processor, so it will be strange if it not working.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11773977
18 hours ago, Brooksie359 said:
This helps with the turboboost functionality but isn't nessisary.
Turboboost will work regardless. Its locked CPU, and while voltages can be bit high, locked i5 on stock cooler isn't going to hit dangerous temps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11776137
It turbos based on temps so if they aren't good it won't be able to boost as high for as long depending on the workload.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11776268
The limit is at 85C. It won't be at that temp unless under really heavy rendering or artificial stress.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11776472
Completely depends on airflow in the case and ambient temperature. There are people who have had thermal throttling with the stock cooler on the i5 8400. That's why I brought it up.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11776965
The stock cooler is fine for normal use, but no CPU is the same. I've heard that some have had their 8400 thermal throttle whilst under 100% load.
Any CPU cooler will work, as any CPU cooler (Nowadays) is better than the stock intel cooler.
https://pcpartpicker.com/product/3jTmP6/arctic-cooling-cpu-cooler-ucacoap11301bua01 This cooler is dirt cheap and cools better than the stock intel cooler. It's not silent, but it's not as loud the the stock cooler.
Alternatively, you could go for something way better. https://pcpartpicker.com/product/LPVBD3/cryorig-cpu-cooler-m9i Much more silent, performs much better and looks a lot better. Killer value for 20$.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11779592
Check your load temps. If they're more than ~80-90c at load, a better cooler would help. Otherwise, stick with stock.
https://linustechtips.com/topic/974091-cooler-i5-8400/#findComment-11780726
