Two Motherboard Questions
Solved by Cereal5,
Yes, your CPU determines the number of PCIe lanes you have, and the motherboard only determines how they are used. As for the board, I would go with the Prime X470 Pro, cause it's $25 cheaper. If they're basically the same board then I see no point in spending more for the same thing. Also, the Prime X470 Pro has better equal to better reviews.
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning1 -
Xrniu ·
Posted in New Builds and Planning2 -
8
3
