Hello!
I have an overclocked i7 7700k running at 5.1Ghz at 1.36v. But what is the maximum voltage for a chip like this? When i ask people, i get answers from 1.3v to 1.5v for daily use (but i just need to make sure i won't kill this chip by pulling too much voltage through it, just to run that 100mhz faster) My cooling solution is superb, as you can check out my (ghetto) rig down below. (Currently finishing it)
https://www.overclock.net/forum/rigbuilder.php?do=rig&action=view&rigid=6849864
Under gaming load, the CPU hits about 40-50c. While stresstesting, the CPU hits about 45-60c. This gives me plenty of heatroom, while still having a quiet PC. (fans running at 40%)
https://linustechtips.com/topic/972502-maximum-voltage-i7-7700k/
There is no clear line that says "do not cross" on a CPU.
That's why people recommend a range.
Yeah, i figured that out as well. But maybe i need to be more specific; 24/7 use under a fair amount of load during that time, without losing much of it's lifespan. I mean, i don't mind pulling 1.5v through the CPU, as long as it does not affect the lifespan too much.
There is no concrete data or test that has any statistically significant result.
If you're concerned about lifespan stick closer to 1.3, if you want to take more risks then go to 1.4-1.5 if your cooling allows.
Haha alright, well 1.3v is just a bit above the stock voltage so i don't really want to stick to that voltage.
My cooling will for sure allow me to pull 1.5v or higher through the CPU, so that's not my biggest concern.
Do other people have an opinion about the voltage? Let me know!
how long do you want the CPU to work? What kind of cooling you have?
Desktop benching:
I want an expected lifetime of at least 3-4 years (with the intention to re-sell it for a low price). My cooling can be found here: https://www.overclock.net/forum/rigbuilder.php?do=rig&action=view&rigid=6849864
a custom loop with 360mm radiator? Then you can try 1.45V, but be careful with the temperature.
Desktop benching:
Temperatures are no issue, but i don't think there is a lot room left for a decent increase of mhz. At 1.408v and 5.2Ghz the CPU crashes after about 15 minutes, and the temperatures are max 60-65c. To hit 5.2Ghz, i might have to push all the way up to 1.45v or higher, which is not worth that 100mhz for daily use. Might go as far as i can for just benchmarking, but nothing else than that.
that's what happens at the end of the voltage/frequency curve, you start shoving a lot more voltage just for a small frequency bump
Desktop benching:
Yeah, i just stick to the 5.1Ghz 1.36v for daily use. Maybe for benching i’ll go higher than 1.4v but not worth for a 100Mhz increase in daily use.
