is it legit to use molex - pcie adapters? I own a 600w Xilence PSU (non modular) but it only has one 6+2 pin pcie plug.
if i wanted to hook up anything above a gtx 1070 i would need at least 2 power plugs but i only have one...
is it possible to solve this problem by using a cheap molex to pcie adapter or are there some disadvantages... i mean 600 w for an i7 7th gen stock and a gtx 1080 should be fine and the fe card only requires one 8 pin but bad cooler and not available at the time... so could i use these adapters?
https://linustechtips.com/topic/972005-not-enough-pcie-connectors/
No please get a decent psu before sticking a gpu of this caliber into your pc.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Wont bother with adapters on rubbish PSUs when you have the money for a new PSU (tier 3 or above in the PSU tier list, pinned to the top in the PSU subforums). Besides, these adapters are sketchy made themselves
Desktop benching:
There is a reason why.
Because its not a real 600W PSU, its garbage that is labeled as 600W, probably like 300W inside.
Quote
Dude, you are trying to power a 500€ GPU with a 20€ PSU.
A shitty PSU will destroy your components!
So get a good one so that you can have fun with the PC longer...
"Hell is full of good meanings, but Heaven is full of good works"
Your PSU is crap. That's why it's a "600W" unit with only 150W of available PCIe connection power draw.
Replace your current PSU with something like a Seasonic Focus Plus Gold or Corsair TXM. An i7 and 1080, without OC, will use less than 300W.
Oh lord. If your PSU requires you to use Molex adapters and it's labeled as a 600 watt unit, chances are that it's incredibly shit.
