It's hard to find a decent case that has good airflow, not tempered glass and easily fit in a bag.
Currently using Node 202. Don't know about Phanteks SFX case that much though.
Intel i7 8700 | TridentZ RGB 2x8GB 3200MHz | Node 202 | Cryorig C7 Cu | MSI GTX 1080 Gaming X 8GB OC'ed | WD Black M.2 PCIE NVMe 500GB/WD Blue M.2 SATA 500GB | Gigabyte Z370N-WIFI | Corsair SF600
https://linustechtips.com/topic/971202-sfx-case-recommendation/
Silverstone also makes good itx cases for backpack/handle use, but I'm not sure theyre much of an upgrade to the Node 202
https://linustechtips.com/topic/971202-sfx-case-recommendation/#findComment-11746234
We don't RVZ03 in our country though.
We do have RVZ02
https://linustechtips.com/topic/971202-sfx-case-recommendation/#findComment-11746239
We do have RVZ02
It's very similar.
They also have the ML08 (you basically have a few different option of styles and features, assuming they're available)
https://linustechtips.com/topic/971202-sfx-case-recommendation/#findComment-11746254
