I'm tired of looking at cases on new egg and then going off to youtube to see a review/build... there are so many.
I've come across the Fractal Design Focus G which nearly approximates my preference. Plain, simple, nothing really fancy.
Should I check anything else?
Must be available on Newegg or Amazon.
5.25" bay
ATX board
using a cpu stock cooler
Price below $70
Easy HDD access
Bonuses: SD card reader and USB 3.0 A on the front or top.
Ryzen 7 2700x | MSI B450 Tomahawk | GTX 780 Windforce | 16GB 3200
Dell 3007WFP | 2xDell 2001FP | Logitech G710 | Logitech G710 | Team Wolf Void Ray | Strafe RGB MX Silent
iPhone 8 Plus ZTE Axon 7 | iPad Air 2 | Nvidia Shield Tablet 32gig LTE | Lenovo W700DS
https://linustechtips.com/topic/971090-case-recommendation/
Focus G is a solid choice. Has good room for expandability too if you wanted to upgrade your hardware
https://linustechtips.com/topic/971090-case-recommendation/#findComment-11745606
