Old fujistu 775 mobo cpu cooler replacement
20 minutes ago, YoungWheels said:
Ah I found a picture of the motherboard as well as the one you provided, I am most certain that you won't be able to fit any aftermarket CPU coolers onto it because of the socket mounting being completely proprietary - meaning that the mounting holes on that motherboard are designed only for the cooler that came with your computer.
From what I am observing the motherboard is mounted onto a metal tray inside the computer's case, and when the cooler that came with the computer originally is put on, it screws down into that metal tray. If you weren't having any of issues with your older CPU cooler - then just leave it how it was and reinstall the original cooler.
Also, there is a fan right next to were the CPU's heatsink sits so that is probably responsible for cooling the CPU/heatsink.
I hope this helps!
