Are these CPU temps OK?
Hi, I have recently made my first 'build', to just make a machine that I could tinker with, etc. Anyways, the only problem I am having is, the CPU temps. Currently, with nothing running, the CPU is usually around 52-60C, but when I start doing something (Chrome, Steam, etc) it usually goes up to 70-80C, with it very rarely reaching 90C and usually ends up around Low 70s when left running Chrome. I am wondering, is this alright, and not damaging the CPU?
I also want to note that the CPU cooler did not fit on the motherboard at all, so it is currently just resting ontop of the CPU, with no thermal paste (as I have none).
Build details: https://linustechtips.com/main/topic/969776-my-first-real-build/
https://linustechtips.com/topic/969884-are-these-cpu-temps-ok/
just use artic silver 3
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/969884-are-these-cpu-temps-ok/#findComment-11733398
Just buy real thermal paste. Anything. And find correct cooler or mount current one tightly with zipties etc. Right now you could as well take heatsink off and put block of copper or aluminum there and have same temps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/969884-are-these-cpu-temps-ok/#findComment-11734994
Alright, I will definitely look into getting thermal paste. Looks like its pretty cheap on ebay
https://linustechtips.com/topic/969884-are-these-cpu-temps-ok/#findComment-11735057
