Cat 5e is the minimum what you want, Cat 6 will be perfectly acceptable.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
1 minute ago, ManosMax13 said:
Will i get anything more if i use cat 6e or cat7?
no. You will only see improvement if you have over 1gig internet or LAN needs.
Community Standards
"Beast Mode"
2 minutes ago, theblastman21 said:
Cat6 sould be fine.
So cat6e wont offer anything because they are almost the same price?
Cat 6e wont offer you any benefit at your speeds.
Community Standards
"Beast Mode"
1 minute ago, Electronics Wizardy said:
no extra speed. Cat5 and above will all have the same speed as you limited by your isp.
Cat 6 will get you 10gb. So will cat 7. Just get a cat 6 cable.
ok thanks
Also whats 6a
Also whats 6a
Cat6 Cat6a
Frequency Up to 250 MHz Up to 500 MHz
Cost Varies by length and manufacturer, with $0.40 - $0.60 per foot as an average; generally about 20% higher than Cat5e. Varies by length and manufacturer, with $0.55 - $0.85 per foot as an average; generally about 20-35% higher than Cat6.
Maximum Cable Length 100 meters for slower network speeds (up to 1,000 Mbps) and higher network speeds over short distances. For Gigabit Ethernet, 55 meters max, with 33 meters in high crosstalk conditions. 100 meters across all systems and conditions for Gigabit Ethernet.
Standard gauges in conductors 22-24 AWG wire 16-20 AWG wire
Theoretical Top Speed 10 Gbps over 33-55 meters (110-165 feet) of cable 10 Gbps over 100 meters (330 feet) of cable
source:https://www.diffen.com/difference/Cat6_vs_Cat6a
Just in case you two aren't aware:
Cat6e is a literally made up nonsense spec invented by Cable manufacturers. It has no definition, and no spec to adhere to.
Cat6a is the actual extension to Cat6.
Also whats 6a
Cat6a (Cat6 augmented) is the revision to Cat6. It improved some of the specs, making it handle higher speeds for longer distances.
Do not ever buy a cable labelled as "Cat6e".
To answer your question: You can use any of the following with no performance issues
Cat5e
Cat6
Cat6a
Cat7
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
