30 minutes ago, Belbs said:
thanks dude. but it's fully modular. is there any non-modular?
Seasonic S12II 620W
26 minutes ago, Uptivuptiz said:
Corsair CX550 550W is a good one :)
No. Avoid the CX series if you intend to any sort of gaming or strenuous rendering. They are office PSU's designed for light work loads.
If you like going with Corsair, the HX series is a much better option.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714577
12 minutes ago, voiha said:
Seasonic M12II-620 EVO
3 minutes ago, voiha said:
Seasonic S12II 620W
If you're clueless, please avoid giving bad advice. The S12 II and M12 II are ancient, loud and lack protections. They are extremely rarely worth it.
The grey label CX/M is much, much better than the S12 II/M12 II. It's fine for low-mid range PCs. And we don't know OP's specs, because noone as asked them, so we don't know what kind of PSUs would make sense.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714589
specs are Ryzen 5 1500x @ 3.7ghz, Sapphire Nitro Rx 480 4gb factory OC, with 500gb SSD, 1tb HDD, 4 fans, 8gb ram @ 2400mhz
https://linustechtips.com/topic/967931-power-supply/#findComment-11714597
5 minutes ago, voiha said:
What are you talking about ? Anicent ? Lack of protection ? They were Tier 2. He stated he wanted non modular so I commented that "Seasonic S12II 620W" IS non-modular. What's up with you and this attitude. CX better than seasonics S12 II :D
Lemme pull some threads about your "good" CX Lineup
Example 1
Example 2
Example 3
https://linustechtips.com/topic/967931-power-supply/#findComment-11714603
Hm, interesting. I have a CX in my system... Normally I don't push it to the limit, but it's close. Haven't had any problems.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/967931-power-supply/#findComment-11714608
Yeah, they do the job, I'm not saying otherwise. It's just that it is stated in numerous articles, tests etc. That Corsair did a bad job with the CX for it's money pre-2017 model. But that guy @seon123 makes an uneducated comment which I don't like. Especially the
part, which grinded my gear.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714624
So a good 400-450W is plenty. Depending on what's available and the pricing, Pure Power 10 400W, CX450/M, Vengenace 400W, Focus Gold 450W or Formula Gold 450W.
Example 1
Example 2
Example 3
And how about some people that actually know what they're talking about, and aren't just the average clueless tomshardware user? Or literally any real evidence? Cybenetics has testing, Aris has testing.
Also, just check the protection chip in the S12 II, and when it launched. I don't care about the outdated, crappy PSU tier list on tomshardware.
Please, just stop, you're making my brain hurt with your incompetance.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714627
cringe.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714692
1 hour ago, Belbs said:
what's a good non-modular, 80+ bronze power supply in the 500w-600w range with all black cables? all feedback is appreciated. thank you!
There are none!
As the price difference in manufacturing between 80plus Bronze and Gold is very slim and on the level of barely noticable, the problem is that the price difference between a good quality Bronze one and an entry level GOld one is very small and like 5€, maybe 10.
But for the +10€ you get a way better unit that can extend the Life of the Components. Like a Bitfenix Formula or for a bit more Cougar GX-F, Whisper M.
Why the hell are you recommending such ancient garbage?!
The S12-II was OKish 8 years ago when it came out, right now we have 8 Years later and haswell happened. And Kepler. And Maxwell. And Pascal. All those things made this PSU worse and worse.
But that's not the worst part. That is that the Fan of the PSU revs up to ~2000rpm at higher loads and that it doesn't have undervoltage detection on +12V, OVer Current on any rail!
That means if something goes wrong, the possibility of the component to catch fire is high.
So pls stop recommending such ancient shit, even if they come with "Wapanese" Capacitors that are made in china as everything else is.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/967931-power-supply/#findComment-11714766
What are you talking about? Anicent?
Yes, the unit came out in 2010, we have 8 years later.
That's why its ancient and must not be recommended as it is not designed for the power consumption of modern components at all. Because at the time there wasn't even haswell.
Besides that, the thing you recommended regulates +5V and +12V together while the CX you said to not buy regulates +5V independently from the +12V load. So that alone tells you that the CX is better as you must not recommend a PSU without independent regulation today.
Lack of protection?
Protection:
https://www.computerbase.de/2017-07/cooler-master-cougar-xfx-zalman-netzteil-test/3/#abschnitt_schutzschaltungen
XFX XT500 (zweite Revision) Is Seasonic S12II-Bronze based. And look at the Protection!
Its at 1,8V on 3,3V and 3,94V on +5V. At OPP Test they saw 8,7V on +12V, 3,3V on +12V and 2,6V on 3,3V.
You call that good? SRYSLY?!
Fan RPM:
https://www.computerbase.de/2017-07/cooler-master-cougar-xfx-zalman-netzteil-test/4/
They were Tier 2.
Yes and they are not now for like a year or so because people brought up some evidence that the "Tier 2" was not deserved for this unit because of voltage regulation and lack of protection.
Hm, maybe it is because you recommended a unit that will cause problems, that is pretty bad and can even damage the hardware...
And we also have a Thread about this glorious unit:
Yeah because its not hard to be better than S12II-Bronze these days as even HEC can do that as you see in the Link I've provided.
The Cougar VTX had better voltage regulation, working protection and stayed in spec in the Computerbase review while the unit you recommended failed in Crossload minor and went to 12,88V.
Example 1
Example 2
Example 3
Oh do you have some facts that provide any proof of the claim?
I provided some facts that speak against the Seasonic. What do you have?
And we are talking about the new one that comes from Great Wall and uses the same Plattform as TX-M if you are lucky, if not its something like a CWT GPS based unit, though cheaper, both use independent voltage regulation though.
Oh wait, I have proof for what @seon123 is saying. Also from Tomshardware. You should maybe take a look at the Reviews:
https://www.tomshardware.com/reviews/corsair-cx450-psu,5678.html
https://linustechtips.com/topic/967931-power-supply/#findComment-11714793
Protection:
Fan RPM:
Nice rant
https://linustechtips.com/topic/967931-power-supply/#findComment-11714798
A slight nitpick, the CXm grey label series, which is pretty decent for a budget unit, released in 2015, only the non-modular variant refreshed in 2017.
cringe.
8 minutes ago, voiha said:
Nice rant
You aren't adding to the conversation here, and I've yet to see you link any real reviews from proper reviewers who know what they are talking about, you claim the CX550 is an office PSU and is not good but that the S12II *is* good, despite it's lack of protections and old, outdated topology (Half Bridge Group Regulated) whilst the CX uses a much more modern topology (Half Bridge LLC Resonant Conversion with Synchronous Rectification and DC-DC) and has working protections.
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/967931-power-supply/#findComment-11714816
You're adding something new to the conversation ? Somebody else already explained that.
https://linustechtips.com/topic/967931-power-supply/#findComment-11714823
Example 1
Example 2
Example 3
The OLD CX was a group-regulated outdated low-temp tolerance mess. The new ones (2015 and 2017 units) are much better than the antiquated S12 and M12.
Standards change. Group-regulation means a PSU isn't Haswell compatible by electrical engineering definition. People shouldn't be using group-regulated units in modern systems. I am the author of our PSU tier list, in the event you want to check the list.
3 hours ago, voiha said:
Nice rant
You offer zero evidence and the advice you give is poor. I think he's justified in his rant. If you want to give bad advice to people buying stuff, go work in car sales for Fiat-Chrysler. Stefan and seon actually know what they're talking about here. If you kept yourself even remotely up to date with the market of PSUs, you'd realize we ditched the old CX series when Obama was still US president.
5 hours ago, Firewrath9 said:
EVGA has some, why do you not want modular? BQ is pretty good.
No it isn't.
What are your system specs?
https://linustechtips.com/topic/967931-power-supply/#findComment-11715553
Not entirely true - you can get a group regulated PSU to be Haswell compliant, BeQuiet System Power L8 for example will not shut down nor go out of spec (though it's pushing it).
PCs:
https://linustechtips.com/topic/967931-power-supply/#findComment-11715580
Well, one example definitely doesn't offset the fact that most can't deal with the low-loads on the minor rails, but sure, I guess the one unit can be an exception :P
Here
Thx
A Corsair CX450/CX450M would be fine for your rig. If you want a better unit then look for a Bitfenix Whisper/Formula Gold, Seasonic Focus Plus Gold, Corsair TXM, or Antec HCG Gold. EVGA has some good units too like the G2/G3.
450W is enough but some of those units only offer 550W as a minimum.
https://linustechtips.com/topic/967931-power-supply/#findComment-11715606
Have you seen any tests confirming that?
I only saw one review testing Haswell compatibility of Be Quiet Pure Power L8 500W, and it failed. https://www.techpowerup.com/reviews/beQuiet/PurePower_L8_500W/5.html
Edit: Misread "System Power" as "Pure Power". Did you see any legit tests of System Power 8 that confirm that?
https://linustechtips.com/topic/967931-power-supply/#findComment-11715931
https://hexus.net/tech/reviews/psu/57705-quiet-pure-power-l8-500w/?page=2
It gets close, but even with 12A on each minor rail and 0.1A on the 12V it *just* stays in spec.
PCs:
https://linustechtips.com/topic/967931-power-supply/#findComment-11716514
