Move softwares from another hard drive
Solved by userzero,
Well, not really. Even if you physically just moved it, it likely won't work.
Either you clone the original HDD to it and you're good to go straight away..
Or get the installation media and start a fresh.
With Steam I usually install the client, set the game installing, close it all down, dump the game files in from my old HDD, Start it up again and let it finish, verify game files. That's about it.
Featured Topics
2
Tbaile ·
Posted in Laptops and Pre-Built Systems2 -
2
fxuplodeskyking ·
Posted in Troubleshooting0 -
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
