PCPartPicker part list: https://uk.pcpartpicker.com/list/HjxGhy
Price breakdown by merchant: https://uk.pcpartpicker.com/list/HjxGhy/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (£159.54 @ Aria PC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  (£34.99 @ Overclockers.co.uk)
Motherboard: Asus - ROG STRIX B360-F GAMING ATX LGA1151 Motherboard  (£116.99 @ Ebuyer)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-2400 Memory  (£149.99 @ Overclockers.co.uk)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  (£23.99 @ Novatech)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£47.94 @ Aria PC)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  (£371.99 @ Aria PC)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£75.97 @ Amazon UK)
Total: £981.40
Generated by PCPartPicker 2018-08-23 12:06 BST+0100
thats my build so far and need a case with good airflow wanting 3 fans at front 2 on top and 1 at back would be bonus if case came with rgb fans but if not can just order them separate. Can anyone recommend a few different cases please ?
https://linustechtips.com/topic/963711-need-a-case-with-mesh-front/
If you really like airflow, the H500M is a good option.
Make sure you get the M version tough, as that one has the mesh. The normal H500 is a terrible case!
I think you mean the H500P Mesh version. And that the H500P is the terrible version
There's 4 Cooler master H500 cases;
H500; Budget variation, Mesh front, panels reduced in size and complexity
H500P; Original, plastic front restricting airflow, bad quality panels
H500P Mesh; Improved panel quality, Mesh Front panel for better airflow
H500M. Addressible RGB fans, Different styled front and top panels, USB Type C, Swappable mesh or Tempered glass front panels (use the Mesh)
https://uk.pcpartpicker.com/product/2mQRsY/phanteks-enthoo-pro-m-tempered-glass-atx-mid-tower-case-ph-es515ptg_bk
https://uk.pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg
https://uk.pcpartpicker.com/product/ZHmxFT/fractal-design-focus-g-black-atx-mid-tower-case-fd-ca-focus-bk-w
https://uk.pcpartpicker.com/product/G766Mp/cooler-master-mastercase-h500-atx-mid-tower-case-mcm-h500-ignn-s00
Good cases with mesh fronts under 100 pounds
2 minutes ago, MrEleven1181 said:
Thanks think i will go with the Fractal Design - Meshify C Dark TG ATX Mid Tower Case. Could you recommend rgb fans for inside looking for 6 total ?
You'll want something Asus Aura Sync compatible so you can control them with your motherboard.
https://www.asus.com/campaign/aura/us/Partners-and-promotions.html
My personal recommendation form this is the Cooler Master Fan Pro 120mm, I'm using the 200mm version in my current system and both the cooling and lights are good. You will need splitters to connect all six fans to the same RGB header though
I am looking for fans that have a rainbow effect do these have this feature? Not really up on pc building lol just been told by , daughter thats what she wants.
They will do that, RGB is very customizable.
You'll want this to be able to make all the fans be the same color and work with Aura Sync
https://www.amazon.com/Splitter-Connector-Strips-12inch-4Splitter/dp/B072K21JVF/ref=pd_bxgy_147_img_2?_encoding=UTF8&pd_rd_i=B072K21JVF&pd_rd_r=455ee654-a6ec-11e8-81f4-6951fe5af5cc&pd_rd_w=UJPNB&pd_rd_wg=4x9qu&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=7ca3846a-7fcf-4568-9727-1bc2d7b4d5e0&pf_rd_r=QNF7W480RYA2J43CXY65&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=QNF7W480RYA2J43CXY65
(Plug one of the female ends into the Four make ends of the second extension, and you'll have 7 RGB connections that can be controlled by one motherboard header)
Here's a tutorial on the software. Note you'll only have Motherboard (and possibly RAM) as controllable options
Ok so 6 of they fans and a pack of conectors and i am all set. I am puting the pc parts into a shop to build it, dont trust myself lol so when i just get it back I download the app and its all good ?
Pretty much! Just make sure to tell them to use the adapters in that link to hook up all six fans to the motherboard connector
@TVwazhere finally got the build read about to start ordering parts https://uk.pcpartpicker.com/list/yYK3NQ just noticed the fan splitter cables are amazon .com. Could you link a uk version please. I had a look on amazon .co.uk but wasnt 100% sure what ones to order.
https://www.amazon.co.uk/Splitter-Ports-Female-Connection-Changing/dp/B010DA0WI6/ref=sr_1_3?ie=UTF8&qid=1535372359&sr=8-3&keywords=4+Pins+LED+Splitter
I apologize for the delay, I was gone over the weekend.
