maximize it, then drag it around
Desktop benching:
https://linustechtips.com/topic/962103-a-stupid-problem/#findComment-11660760
Just now, PatXioPC said:
If I can't even reach the window, how am I supposed to be able to interact with application UI?
you dont need to, you can maximize it through the taskbar. point your cursor to the preview of the window, right click, and click the 'maximize' option
Desktop benching:
https://linustechtips.com/topic/962103-a-stupid-problem/#findComment-11660763
Click on Steam in the taskbar (so it's your 'active window') and then Press Windows + Up arrow key (maybe two times, if it doesn't work on the first try)
https://linustechtips.com/topic/962103-a-stupid-problem/#findComment-11660764
