Subdomain to Port (DNS help please)
JCBiggs
I have a domain that i have used for years.
Mail.example.com  points to google with a CName and MX records  so I log directly into my g suite account.
I am trying to set up  "cams.example.com"   with that directed to my home (static) ip address/server.   this also has to be specifically directed to port 81.
Can anyone help me with this?
setup a srv record.
What issue are you having?  It's easy to specify a nonstandard port like http://cams example.com:81
I wouldn't submit any credentials without ssl or VPN however.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
Im just trying to figure out how to do it.  you say its easy, but the only way i have found is to setup a nginx webser with reverse proxy on the same machine. another guy tells me it should all be port 443 traffic (https)  instead of port 80... i hear what their saying. makes sense, i just cant figure out how to make it happen! I dont want to put to big of a gaping security hole in my home network!
The more secure solution would be to establish a VPN and connect to your cams over that once you authenticate.
sure, but I want other users to just use the web address. I have a VPN for my personal stuff, this should be public.
**public but with credentials
