USB Audio Snap, Crackle, Pop
39 minutes ago, Tyler Moore said:Sometimes if clock speeds are not right you can experience this problem. I couldn't say that's your problem, can't say for sure what is but definitely keep searching and post if you find a fix. I'll see what I can track/locate but being this happens on two computers, I'd try another PC (be it a friends or library or w/e).
This issue may even be that you bought defective gear. Could be you setup the system wrong or forgot some things.
And in case I haven't said it and it ends up being a fix, have you tried downloading the driver for the headset from the website itself? How does that compare to Windows selected driver?
Definitely hope we can get light on this, audio problems are not fun with computers.
So Idk if this is a permanent solution, but I have decided to switch to google chrome instead of firefox. I get much much less of the audio issues using chrome it seems. But this is obviously not the main issue because I still get weird audio issues other places (outside of browsers).
