9 hours ago, GivenchyGaming94 said:
Hi guys, im currently using a N200 case by cooler master and i would like to upgrade my case, i have a ASUS STRIX 980ti which is rather long. Any recommendations on a good case? Thanks!!!!
Do you have a budget?
For under $50, the Fractal Design Focus G is very good. If you want Tempered glass, there are good options under $100
RGB Build Post 2019--- Rainbow 馃 2020---Velka 5 V2.0 Build 2021
Purple Build Post ---Blue Build Post---Blue Build Post 2018---Project ITNOS
CPUAMDR7 7800X3D聽 聽聽MotherboardAsrock B650E Taichi Lite聽 聽聽RAMCorsair Vengeance RGB 32GB 5200mhz聽聽 聽GPUASUS RTX4080 STRIX聽
CaseFractal Torrent聽 聽StorageSamsung 980Pro 2TB, Crucial P3 Plus 4TB x2,聽 聽 聽PSUCorsair RM1000x聽 聽聽CoolingDeepcool AK620
https://linustechtips.com/topic/956669-cases-help/#findComment-11616598
Phanteks Pro M / Special Edition
https://www.newegg.com/Product/Product.aspx?Item=N82E16811854042
or聽
Meshify C
My picks for best cases offered at this time.
Best聽& worst cases for your money in 2018 are:
Best Cases overall
I)聽Fractal Design Meshify C - Airflow and relatively聽quiet, best all around case
I)聽Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I)聽Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent聽
I) Fractal Design Meshify C mini (mATX)
I)聽Corsair 400C - Only use with low end components, no 1080 / TI
I)聽Phanteks 350X -聽Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I)聽Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable聽for low end builds
The worst cases - Do Not Buy
I)聽NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I)聽Coolermaster聽Masterbox 5
Majority of cases on the market
https://linustechtips.com/topic/956669-cases-help/#findComment-11617486
What are the rest of your specs? Is there anything in particular you're looking for in the case?
Where are you shopping / located? Budget?
https://linustechtips.com/topic/956669-cases-help/#findComment-11617497
