Hello!
At the moment my GTX 680 lightning is the loudest part of my pc when idling, and afterburner only allows me to turn the fans down to 30% even though the temps are <30*C.
Does anyone know if there is a way to lower it even further (except from water cooling it xD)?
Hope someone might have some tips, tricks and experience they are willing to share :D
System specs
CM Storm Stryker
Corsair AX760i
MSI MPower z77
MSI GTX 680 lightning
Intel i7 3770k
Corsair H100i w/Noctua NF-F12's
Avexir Core series MPower edition 32gb
ASUS Xonar DGX
Samsung 840 pro 256gb
Seagate Barracuda 2tb
Bitfenix white sleeved cables (yep, even the front panel audio)
Silverstone Air penetrator 120mm
With Windows 8, 64bit
https://linustechtips.com/topic/95616-after-burner/
Can you use a different software program? (GPU tweak?)
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/95616-after-burner/#findComment-1280175
You can't go lower than 26%. All the OC utilities are the same but with different layouts and skins.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280179
Hello!
System specs
CM Storm Stryker
Corsair AX760i
MSI MPower z77
Intel i7 3770k
ASUS Xonar DGX
I use EVGA precision and is allow the fan to go below 30%
Scrap that sorry.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/95616-after-burner/#findComment-1280181
Thanks! I'll try it out as soon as possible.
It works even though it's not an EVGA card?
Sorry, read my edited post.
It allows me to set my fan curve to below 30%  but doesn't actually go below the set percentage.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280199
The difference between 26% and 30% is negligible anyway. I don't think you realize how little a difference it would make.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280222
But it's something, right ;P
An inaudible difference.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280234
30% shouldn't be that loud O.o Unless you want complete and utter silence, my 680 DCUII is whisper quiet at idle.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/95616-after-burner/#findComment-1280236
Aww, that's a shame :P
Nice memory though.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280237
 My reference 780s sit at 30% on idle and they're whisper quiet.
https://linustechtips.com/topic/95616-after-burner/#findComment-1280240
Are you sure it's the graphics card that's loud and not the H100i's fans?
https://linustechtips.com/topic/95616-after-burner/#findComment-1280291
Off topic what's up with the 3rd RAM stick?
I love avexir's RAM, sounds childish but basically a rave inside your case.
Shot this video for another purpose, but it shows the Avexirs quite good (except the colours are a bit of)
http://youtu.be/EJVKoCmQ3ZU
https://linustechtips.com/topic/95616-after-burner/#findComment-1280314
