No side panel
Just make sure you clean up the glass shards.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/955653-no-side-panel/#findComment-11606608
Nar just walk on them and train some endurance stats.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/955653-no-side-panel/#findComment-11606616
Just now, XxBatman99xX said:
I already have. This happened on Wednesday. Tried to get it for free, but would’ve had to send the whole case (wtf?)
If it was damaged by user error (which since the system is assembled, most likely was), they most likely wouldn't send you a replacement for free. I guess they thought it was damaged in shipping which means they would replace the entire unit.
https://linustechtips.com/topic/955653-no-side-panel/#findComment-11606640
It would be dusty and might hurt temps a bit, but yes you could
https://linustechtips.com/topic/955653-no-side-panel/#findComment-11606862
