Hi this is my first post and first pc build can someone please check over my list and advice me?
my budget is 1500 ish CAD
also going to be my school/ maybe some light game pc
since it is going to be my main pc I want the side window if the H500M and the rgb :)
I would go with something like this
PCPartPicker part list: https://ca.pcpartpicker.com/list/wthCD2
Price breakdown by merchant: https://ca.pcpartpicker.com/list/wthCD2/by_merchant/
CPU: AMD - Ryzen 7 2700 3.2GHz 8-Core Processor  ($374.99 @ Amazon Canada)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($86.00 @ Vuugo)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($189.99 @ Newegg Canada)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($60.99 @ PC-Canada)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($74.49 @ Newegg Canada)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($379.99 @ Memory Express)
Case: Cooler Master - MasterCase H500P ATX Mid Tower Case  ($137.00 @ Vuugo)
Power Supply: SeaSonic - G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($90.99 @ PC-Canada)
Total: $1394.44
Generated by PCPartPicker 2018-07-25 13:38 EDT-0400
Just now, Firewrath9 said:
a b360 chipset is not compatible with ryzen. i suppose you mean a b350 chipset.
Oh and here is my current rig I have been using since 2008 ( cringe all you want)
prebuilt LG pc
core i2 duo
stock cooler
motherboard is Asus p5kcl-cm
3 gb of unknown ram
500 gb hdd (yes I lived of 500gb for 10 years, but the amount of times I had to completely wipe the computer probably helped)
some unrecognisable cooler master psu
random optical drive
and random box case
moniter is flatron w2242tg by lg ( have to keep the monitor)
keyboard and mouse are Logitech keyboard is deluxe 250
2 minutes ago, Jas99 said:
Pretty much but I want it to be future proof since I might be stuck with it for 10 or so years
If the goal is to spend $1500 on a PC to use for the next 10 years, I suggest instead getting a useable PC now and then upgrading or replacing the system later.
Spending so much just to make the system light up is quite silly, when it comes at the cost of several hundred dollars and/or a lot of performance.
Something like this would last you for a good while, and have plenty of upgrade options. You could also save more on the system by swapping the platform to Raven Ridge.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($229.99 @ Amazon Canada)
Motherboard: MSI - B360M PRO-VDH Micro ATX LGA1151 Motherboard  ($87.92 @ Mike's Computer Shop)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($96.99 @ Newegg Canada)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($128.99 @ Amazon Canada)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Low Profile Video Card  ($224.99 @ Amazon Canada)
Case: Cooler Master - MasterCase Pro 3 MicroATX Mini Tower Case  ($49.50 @ Vuugo)
Power Supply: SeaSonic - FOCUS Gold 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($89.99 @ Newegg Canada)
Total: $908.37
Generated by PCPartPicker 2018-07-25 13:52 EDT-0400
Welcome to the forum! You can build a much better computer for the money, and there's no reason to be spending $280 on that case; that's insane.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($244.99 @ Memory Express)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler  ($82.10 @ Newegg Canada Marketplace)
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard  ($163.50 @ Vuugo)
Memory: Team - Night Hawk RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($219.99 @ Newegg Canada)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($85.42 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.95 @ Vuugo)
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($287.87 @ Amazon Canada)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($100.75 @ Vuugo)
Total: $1234.57
This build doesn't have the case included, but it shouldn't cost any more than $150.
It has a much better graphics card, RGB RAM, and a much better SSD. If you need more storage there's a little play in the budget.
29 minutes ago, Firewrath9 said:
whats that cooler?
dont get rgb ram or such an expensive mobo.
He wants RGB RAM. There's nothing wrong with that.
Total: $1394.44
The H500 case without mesh is an absolutely awful case though...
There's no such thing as futureproof, and few things last 10 years. You'll have to upgrade something within that time, unless it's just for office work.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
prebuilt LG pc
core i2 duo
stock cooler
3 gb of unknown ram
and random box case
Thanks for the great feedback guys!
59 minutes ago, Jas99 said:
Thanks for the feedback especially to dizmo
but hows this upgraded list
Coolermaster announced the new H500 same price as h500p but updated I think that I might use that instead of H500M, H500P or H500P Mesh so many H500s!
