How easy would it be to get a new mb tray/backplate with 2 slots & replace the one it has with the new one???
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/948672-element-q-with-some-changes/
27 minutes ago, Comic_Sans_MS said:
Grab a multi-tool and and afternoon, and do it yourself.
Would Protocase do it???
I think they usually do original case builds. I dont know if they modify existing cases.
Is there a cad file of it anywhere? Anyway to narrow down the result to chassis here  https://grabcad.com/library ?
