Will 240hz monitor have any downsides at 60fps?
frog8fly
I am looking to buy a monitor. Originally I wanted a 144hz, however, I really like the look of the alienware monitor which is 240hz.
www.amazon.com/gp/aw/d/B0733YCKM5/
I have an i7 8700k and gtx 1070ti. In a game such as Fortnite, I get around 150fps.
Now, I dont want to pay $500, so I am thinking of getting the non g sync version of the monitor.
Will there be any downsides to having the monitor be 240hz vs 144hz, especially considering I cant hit 240 in alot of games? (And I wont have g sync).
Thanks
14 minutes ago, seoz said:
If you can't hit the Hz, then don't get the Hz.
Sounds like he's in for a world of Hz.
Why spend the money on 240Hz if you can't get it? It would be a much better idea to get a 120-165Hz G-sync display, like this one (its even 1440p):   https://pcpartpicker.com/product/CwgPxr/dell-s2417dg-238-165hz-monitor-s2417dg
Current LTT F@H Rank: 98    Score: 2,285,387,178    Stats
Yes, I have 9 monitors.
My main PC (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (VFIO-Patched Kernel) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.11.2
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
if u dont reach those frames get g sync or a moniter with other aspects u like
Lol that monitor is more expensive than the 240hz.
I dont have a need for 1440p, I would much rather hit at least 144fps than have 1440p.
Anyone have a good monitor recommendation that is 144hz 1ms with g sync around $300?
Also, guys, this monitor is a really good deal. So money aside, will their be downsides to getting it if I run my game at 144 fps?
The monitor looks really cool and the future potential of 240hz is interesting.
Thanks
Not really, other than the monitor costing more than a 144 Hz. Although since G-Sync only works when your framerate is lower than your monitor's refresh rate, having a monitor with a high refresh rate that you will never hit is the ideal situation to have G-Sync in.
