I am aware of the corsair vengeance xmp issues. I just built a new rig with 64 gb of ddr5 with a 14900k and a msi edge wifi mobo. I attmpt to throw xmp profile on and the oc failed. I have them set at 5400 speed instead for temp stability but they are rated for 6000. I am not an expert on oc so I could use any tips on getting xmp 6000 stable, thank you.
https://linustechtips.com/topic/1571240-xmp-issues/
Need some more information please.  What are your system specs, especially the mobo, cpu, and ram.  I have found that for most mobo's, if only using 2 sticks of memory, the best slots to use are A2 and B2.  When adjusting the XMP, I go for the "automotic" setting where it puts in the information that it pulls from the ram itself.  I am using Corsair Dominator 6000 and when I turned on XMP, it automatically filled in the information.  I am also using an Asus ROG Strix X670E-E mobo.  I hope that you can figure out your problem soon.
Take care and good luck.
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16417854
Latest Bios?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16417898
12 hours ago, RONOTHAN## said:
What is the exact memory kit model, and what memory slots are you using specifically? Also just to confirm, this is the ATX Edge, not the ITX edge?
ATX Edge. Its the Corsair Vengeance RGB ( 4 sticks ) of 16 a piece for 64 GB at DDR5 6000 C36.
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16418286
I have 4 sticks in of the mentioned above ram in the other quote.
Mobo: MSI MPG Z790 Edge Wifi
14900k
4070 ti
4 sticks of vengeance rgb ( 16 per so 64 gb ) at ddr5 6000 c36
psu is a corsair 1000 watt
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16418293
12 minutes ago, Beansalad. said:
4 sticks
This is going to be a bit of a problem, 4 sticks of DDR5 is hit or miss at best depending on the BIOS revision, motherboard, CPU, and luck. Also, since I'm guessing you're buying two separate 2x16GB kits for this, there's a chance that the sticks you got aren't even identical, in which case 5400 is about as much as you can hope for. Pull all the RAM out and look on each of the sticks for the version number (it'll look like ver. 4.43.13) and report back with what it is.
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16418310
all identical at ver 3.43.04
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16418324
OK, that's going to be a bit of a problem, those ICs have next to no optimization by most board vendors, so 4 DIMM support is going to be questionable at best with these. If you're still within the return window, return both of these kits and at minimum swap to a 6000 CL30 kit (despite being tighter timings, these are actually easier to run because of how much BIOS optimization has been put into it), and preferably just go for 2x32GB rather than 4x16GB.
https://linustechtips.com/topic/1571240-xmp-issues/#findComment-16418355
