I’ve been looking at cases for a while now and can’t really decide.
I was originally going with the h500i but decided that didn’t have enough ventilation at the front.
Cases I’m looking at:
Cougar Puritas tempered glass mid tower
Corsair carbide spec omega rgb
msi mag pylon tempered glass case
Fractal design Meshify C TG
I’d like to case to be mostly black if not all black so I can go with any colour scheme.
Any input on these cases or your opinions are welcome. Or even other case options. Thank you
https://linustechtips.com/topic/947889-help-deciding-on-case/
If you want good airflow, the Silverstone RL06 is also a good choice it's main advantage is coming with 3 decent fans at stock rather than cheap ones meant to past 'out of the box' reviews, which makes it cheaper to use.
Desktop benching:
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11536155
I’ve seen that one, I know I’m being probably too picky but I’m not a big fan of the design.
I don’t need the airflow to be anything crazy, just don’t want it to be too restricted.
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11536162
Id say the Fractal case. Clean and allows you to show off your pc without it being overly flashy. not to mention decent airflow and good cable management
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11536187
30 minutes ago, Menaxerius said:
I recently bought the TG5 RGB, not sure yet how well it is as delivery should arrive tomorrow but that might be an option for you
Regards
I do really like the look of that case but I’m am in Australia and don’t think I can get that here? I’m not too sure but I haven’t seen it anywhere.
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11536280
You can get the Corsair 460x which is a slightly more premium version of the Sharktoon case :)
The Pulon looks like garbage for alirflow. Honestly the NZXT H500 has better airflow than that.
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11540036
Have the Meshify C, amazing case
Ryzen 5 3600 | EVGA CLC240 | EVGA RTX 2070 Super XC Ultra | ASRock B450 Pro4 | 16gb EVGA SuperSC DDR4-3200 | 1tb WD SN550 | 2tb SanDisk Ultra 3DEVGA P2 650w | Fractal Design Meshify CViewSonic VX2758-2KP-MHD + ViewSonic VS2412-H | GHS.RAR (Boba U4s, Staebies, GMK Aurora Polaris + Artisans) | Steelseries Aerox Ghost | Artisan-Japan Ninja FX Hien (M/Soft) | Fostex HP-A3 | Fostex PM0.3G | Fostex T60RP | Beyerdynamic DT 1990 Pro | Beyerdynamic FOX
https://linustechtips.com/topic/947889-help-deciding-on-case/#findComment-11545712
