how can i get my PG27UQ monitor's USB to work with Razer RGB headphone stand
By
saif96
in Peripherals
in Peripherals
Solved by davehkiin,
You see that other USB port beside the 2 USB 3.0 ports? That's the USB 3.0 upstream port. This port is for connection with a USB upstream cable. The connection enables the USB ports on the monitor.
You need to plug it in to your PC For it to throughput to your PC.
Best of luck!
Featured Topics
Lamelou ·
Posted in Troubleshooting0 -
1
1
geekygamer ·
3
HoffmannMS ·
Posted in Displays1 -
matrixman ·
Posted in Troubleshooting1
