Is PCI express card into PCI slot possible?
19 minutes ago, Newbie0 said:If I use the sound card at that slot I won’t be able to use the ports.
What sound card do you have?
If it's an entry level one, the on-board audio would probably be better.
You CAN'T just use the other side of a PCI-E slot.
Each of the pins are wired to a specific part of the board -- you'll kill your add-in card, motherboard, and/or CPU if you try to force things in.
e.g. Pin #1 on the PCI-Express slot is +12v power, while Pin #82 on the other side of the slot is Ground.
"Regular" PCI and PCI-Express are not directly compatible with one another.
Size of the slot, pin count, pin arrangement, and power/voltage are different.
That said, a PCI-E X1 card will work in a PCI-E X1, X4, or X16 slot.
Like so:
