Sound Card vs Intregated Audio
5 hours ago, Newbie0 said:Does my sound card is better than my mobo’s audio?
Better how?
2 hours ago, Newbie0 said:SO you are saying dedicated sound card is not good? Then what about motherboards integrated audio?
(I am not expert in this field so please explain something)
No what he's saying is that the only way to clear out static on the audio, if this is the particular issue, is to remove the audio processing from the case. As with a sound card, it's still in that EMI environment. Additionally, if you look at EMC design, placing an object in parallel to a large source of disturbance actually compounds the issue, especially if it's completely within the circuitloop of that device.
The biggest sources of EMI are the GPU's and their PCB's these days, placing a soundcard directly in it's wake would be worse than the onboard sound which is perpendicular to it's circuitloop and outside of it as well.
5 minutes ago, EsaT said:Need for external fashion "DAC" is same marketing snake oil BS than than those "7.1" headsets.
http://archimago.blogspot.com/2017/04/retro-measure-2002-lynx-l22-pci-audio.html
Parts have changed, switching frequencies have changed, component density has changed. I could clearly hear EMI coming from the speakers when I moved my perhipherals, so I had to move my audio outside of the machine. Granted, it's an ITX.
Also, designing for EMC is not top priority anymore for all AIB's, so this test can be succesful or a failure based on the particular parts. A test on one system is not a conclusive test.
