Hey everyone,
Im planning a new build and the case im getting has a USB 3.1 port on the front with a 3.1 internal cable on the inside like this one:
My problem is that my motherboard does not have this header on it. Are there any Add-in cards or adapters that would let me use the port? I don't really care about the speeds, I just want it to work.
Thanks!
https://linustechtips.com/topic/944666-usb-31-gen2-header-problems/
2 minutes ago, userzero said:
Yes. This question has literally just been asked right now.
Lookup an adapter, they exist.
I did like 30 minutes of googling and I couldn't find one. Could you link me to the post where that was answered or to a product page for one? I would greatly appreciate it.
Really. You must fail at google.
Lookup PCI USB Type C 3.1 adapter card. Or any variant of. Take your pick of ones with HEADERS on them.
Probably gaming or helping technophobes with tech...
Lookup pci type c 3.1 adapter card. Take your pick.
Lol you get these:
Which is 100% not what i am looking for. I want the front panel header connector for usb3.1 Gen2. Not just some ports out the back
1 minute ago, TVwazhere said:
Your the best! That is stupid expensive though. Maybe I'll leave it inoperable lol. Unless anyone else has a solution.
15 minutes ago, Anaconda101 said:
Lol you get these:
Which is 100% why I said get a card with headers on it, not just external ports.
2 minutes ago, Zagna said:
Here's an even more expensive option, Delock PCI Express Card > 1 x internal USB 3.1 Gen 2 key B 20 pin female.
Couple places I could find it was 80€+.
It being on a PCI card though is a real plus. Thanks! Still stupid expensive.
  • 1 year later...
Hey, I know this thread has been dormant for a while, but I found a couple items that are lower cost-- one which is just a USB 3.0 header adapter to the a-key connector at $25 on sale https://www.amazon.com/LINKUP-Internal-Motherboard-Converter-Adapter/dp/B07WG8ZJ41/, and one which is a PCI-E card with full Gen2 speeds for $50 https://www.amazon.com/Ableconn-PEX-UB152-Internal-Express-Adapter/dp/B07PRQWMGG.
