Computer is not recognizing my Ethernet cable
Hello, I was playing video games and I had noticed that I started lagging, normally my ping would be 39-49. Only today my ping was AVG: 70 and would jump to 240. I went into networks and saw that I was not connected to my Ethernet. When I tried to join my Ethernet network it says " unidentified network - No internet access" I reset my PC, still nothing, I reset router, nothing, I plugged my Ethernet in and out, nothing. Any Ideas what I should do?
Does wifi work? The only thing I can imagine is that something is screwed up with the network/router itself
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
3 minutes ago, Yana said:
Update: I have finally made my ethernet show up but now it says "Network - No Internet Access"
first right click on the Ethernet logo on your toolbar and press troubleshoot problems see if that can fix it or give you any clue
Sorry for the late reply, I have done the trouble shooting for the ethernet, and it says Problems found - "Ethernet" doesn't have a valid IP configuration
And it doesnt say my network name anymore the the ethernet network. it says unidentified again
Do you know if your router is actual operational? For example, does WiFi work?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
2 minutes ago, Yana said:
Yes im on it right now, and on my phone as well. both work. went around the house and the TV/netflix , everyone's phones work as well @BlueChinchillaEatingDorito
Try forcing a refresh of your DHCP IP Address. To do this, open Command Prompt. Then enter the following commands.
ipconfig /release
This releases your assigned IP address from use and notifies the router to clear its entry, marking it as available. Now enter this command:
ipconfig /renew
This essentially sends a request to the router to be assigned a new IP Address.
ipconfig /release
ipconfig /renew
Hello, when i renewed it it said "windows ip configuration" after, i hope that normal.
I also ran the troubleshoot windows network diagostics again, and it still says "ethernet" doesnt have a valid ip configuration
Check if its the cable first , swap for another cable.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
