Fan filter on exhaust?
AMD Lover
So i have a 750D which has three fan mounts ON THE TOP and i have two fans out taking on a 240mm rad but that left me with room for one 140mm fan. I much needed a intake to get positive pressure so i put a 140mm fan as an intake there. All is well except that i put the fan filter back on the top to filter dust, which i have a lot of. Is it okay to have the two fans (High Static Press.) blowing through a dust filter. (Note: Dust filter is fairly open, could probably fit a 0.5mm pencil lead tip through.)
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
not a problem, it could even prevent dust from falling in, when the computer is powered off.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
You don't need a filter for exhaust.
Theres one intake fan on the top, take a look at the 750D it has 3 140mm fan mounts with one long fan filter
| F@H STATS |
I think a dust filter is meant to protect not only your computer but also the fans so the fan should be pulling through it.
CPU : Intel Core i7 3960X, Mobo : X79-UD3, Memory : 4x4GB Vengeance Black Memory 1600MHz, GPU : Asus GTX 970 Strix, Case : Switch 810 Matte Black, Storage : 256GB Samsung 830 SSD, Seagate Barracuda 1TB, PSU : Thermaltake 750W 80+ Bronze, Displays : 3x Asus 1080p Screens, Cooling : Corsair H100i, Keyboard : Logitech G710+, Mouse : Madcat Cyborg R.A.T.7, Sound : Sennheiser HD598, V-Moda Crossfade LP, Logitech Z-5500, HMD : Oculus Rift CV1
Kinda what i was thinking bc i've dropped stuff into my case before
| F@H STATS |
Unless you have dust already inside your PC, shouldn't have to  for exhaust, but for double measures, why not?
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
Basically what im saying is that i cant filter my one intake without putting a filter over my two out takes too. So im asking is it going to hurt or cause problems for that fan filter to be over to out takes
| F@H STATS |
no
Why not just get a single filter for the one fan and leave the other two unfiltered? No point in having a filter on the exhaust side of a fan since all it will do is catch dust which by extension will not remove it from inside the case. The only time you should filter an exhaust fan is if the PC is in an extremely dusty environment which would require the user to place a filter on the intake side of the fan for easy cleaning.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
oh dont complicate it... the guy has a fiter already, his cooling wont suffer because he filters the outtake, ergo, no problem with the filter being htere,,,
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
The mesh on top of the 750 is barely a filter, you will have no issues having in on there while using exhausts.
Oh ok I didn't understand well, exhaust don't need fan filters since they take air out the case. Intakes has to be filtered though. Also, intakes are usually near the floor where more dust can come from.
yes, placing the filter over the exhaust fans will imped the amount of
air to get out of the case/radiator(s). at least 4°-8° difference on CPU
temperature, 3° on coolant temperature, 2° on GPU(s) on my 750D
build just by removing the top filter.
