I was wondering if I could use a fuel filter like you see on lawn mowers and install it in a custom loop to filter all the garabage out before putting regular coolant in. I would be using 3/8ths" inner diam. tubing. Thank you in advance.
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/943108-fuel-filter-in-custom-loop/
I think it would be too flow restrictive. Also you're suppose to clean out all the parts prior to use.
The problem is that your water pump is nowhere near as strong as a lawnmower's fuel pump. Unless you put a fuel pump in your cooling loop, it's not really doable.
Besides, your water inside the custom loop is far cleaner than fuel, so no need for that either.
Desktop benching:
Hopefully there is no need for a filter in your loop... Not only would it introduce restriction and new places for potential leaks, it would be a great breeding ground for any bacteria or mold spores that make it in your loop.
If you're dead set on getting a filter in your loop, check out some aftermarket filters used on older motorcycles. They usually feature lower restriction mesh filters due to the fact that those older bikes typically didn't have fuel pumps. Just don't try to shove high pressure through them for some reason...
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
I am afraid I may not be able to get the rads as clean as the need to be.
The reasoning is for making sure the loop is clean before using it with coolant.
ORLY?
Flush it then. That is, water only passes through the radiator once and gets poured out after one cycle.
Desktop benching:
How much water? It is one 80mm x2 (160mm) rad and a 240mm rad.
ORLY?
Till whatever comes out becomes clean? I dont know how badly ruined are the insides of the radiators.
did they hold anything before that makes you want to flush them?
Desktop benching:
I am getting the parts this week (hopefully).
ORLY?
Simple cleaning method i have used and recommend.
Grab your rads, and flush them with boiled tap water.
Fill it, leave it a minute, shake, empty into a WHITE CLEAN bowl. (empty the bowl after each flush)
Keep doing this untill u see no particulate in the white bowl.
Once you confident its clean, do 2 final flushs with distileld water.
Now, if your using some special coolant in the loop, you going to have to use some kind of prep solution. Like Sysprep or Blitz.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
So no good way of getting around cleaning the rads like that huh. Thanks guys.
ORLY?
You can setup an external loop with a high flow filter like one used inline for home and just do the radiators to clear them out. However you will want to still shake and agitate them to remove any loose debris.
Is this something you might be interested in?
https://shop.aquacomputer.de/product_info.php?language=en&products_id=2421
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
I was thinking of that.
I was looking at it earlier but I was not sure of how well it filters. I thought I remembered Jayztwocents using a filter but couldn't find it.
ORLY?
if you want just to clean the system to get as much dirt out of it you can, but do not use then the system is running.
I've done it myself just to filter the system, some electrical tape to get it connected to the loop is not a leack free but it lasted for 5 hours
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
What did you use?
ORLY?
1 hour ago, dual290x said:
What did you use?
A generic fuel filter, (noname, not branded) cost me around 99c at the gas station
Noted, thanks.
ORLY?
In my experience no matter what you do you will still get gunked up blocks from time to time. Rads are usually ok and it's usually not to gunky unless somthing happens to make the dye precipitate out of a fluid. If you want a pretty colored fluid loop then you will need to Clean here and there. If you go strait distilled water with a piece of silver then you won't need to as much.
