mediocre temps.
poor case airflow probably.
Desktop benching:
https://linustechtips.com/topic/941858-are-these-temps-ok/#findComment-11480539
The top readings , at 100c, ignore them. Just bad readings.. seems to be a common issue. Nothing to worry about.
As for the CPU itself. Its a tad toasty.
I would put it under a proper stress test to see how high temps actualy go. Somthing like OCCT or Aida64 CPU test will show if you got a an issue.
Considering your getting that high while just gaming I suspect you might have a cooling problem. 80c isnt a problem, but if at any point you CPu gets put under a harder load than just gaming iwth FarCry, its likely to go higher. Idealy 80c is the highest you'd want to go, but most CPU's are safe right up to 100c, though i most certainly do NOT recommend running at that temp.
Case airflow could be at fault,  could have bad contact with the heatsink and CPU, old dried TIM,  or just an inadequate CPU cooler.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/941858-are-these-temps-ok/#findComment-11481383
Are you using stock cooler? Have you recent cleaned case and/or changed paste? What case, how many fans and where? Whats your room temp?
Temps are on the hotter side, even with stock cooler you shouldn't have 80C under just gaming load.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/941858-are-these-temps-ok/#findComment-11482073
