What's a very good gaming controller, or 'console like' controller for pc? I had this in mind
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104403
I've got rather large hands, playstation and xbox controllers are comfortable to me, n64 are awkward to hold.
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/94141-console-like-controller-for-pc/
Wired Xbox controller works on PC, i use it to
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
I'd rather prefer wireless.
Find a legitimate version of this http://www.amazon.com/Xbox-360-Wireless-Gaming-Receiver-Windows/dp/B000HZFCT2 and that would be your best bet.
I have a knock off i grabbed off of ebay and have no real issues with it, just had to force the drivers.
CPU: AMD FX-8350 - Noctua NH-D14 | Asus Crosshair V Formula | 16GB Kingston HyperX | Plextor M5P Extreme 256GB SSD
GPU - Asus AMD Radeon 6950 Direct CU II 2GB |
Seasonic 1000 W Platinum | Cooler Master 690 ii Advanced | Asus VE248H + VE248Q
Just get a standard controller, i believe the ps4 controller now works for pc, I have small hands so i dont like the xbox360 controller.
Listen if you care.
The razer ones feel nice, very sturdy
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
Get a wired 360 for PC. Its supported by most new games.... Like 95% of new games. No silly key mapping required.
Its also nice to hold and since the drivers are made by MS they just work better with other things like emulators.
I have a PS2, Wii and DS emulator that the 360 controller works perfectly with.
You can get a wireless adapter for a 360 controller and sync it. However the major downfall of the 360s wireless controller is battery life and the sensitivity of the battery pack. If you touch the battery pack in the slightest it might disconnect. Otherwise the controller is flawless in ever respect.
Desert Storm PC | Corsair 600T | ASUS Sabertooth 990FX AM3+ | AMD FX-8350 | MSI 7950 TFIII | 16GB Corsair Vengeance 1600 | Seasonic X650W I Samsung 840 series 500GB SSD
Mobile Devices I ASUS Zenbook UX31E I Nexus 7 (2013) I Nexus 5 32GB (red)
Fuck it, get an SNES controller.  Their baller and you can pick them up off ebay new for about 6 bucks from China.  Plug and play awesomeness if you ask me.  And you can play every emulator you want as well as normal games and be retro all in a little package
Why not just use a wired Xbox 360 controller? Direct plug and play support in most Windows titles. Else glorious mouse and keyboard master peripheral race.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
Yep, got myself a wired XBOX 360 controller for PC and it's simple to use, plug and play, nothing easier than that! No need to configure or map.....it simply works.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
