Hello.
I have an Rx 480 GPU for a year now, and I have not seen this problem before, and its really weird.
When I start the GPU intensive game, particullary Rust, I have like average 25-30 FPS on average on medium settings.
When I start the Windows 10 Task Manager it jumps straight from 30 fps to like 90+. I don't know what is causing this problem, but its getting weird.
Litelary only thing I did was open Task manager. Nothing else.
And after like 5-6 minutes, Task manager shuts its self off, and I am back in mid 30 fps.
https://linustechtips.com/topic/941266-rx-480-fps-lag/
sounds like a driver problem.
Also need more info about your system.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/941266-rx-480-fps-lag/#findComment-11474829
Clean your drivers and re-install would be my first step. If you are still having issues, I'd check the power draw on the card, make sure its getting enough power, and thermals as Konrad said. It also sounds like there could be a vsync/display issue where the game is thinking its capped at 30 fps, I have seen this in a few games. Try running in windowed mode vs fullscreen (and try disabling/enabling vsync) and see if the fps is any different.
Main Rig: cpu: Intel 6600k OC @ 4.5Ghz; gpu: Gigabyte Gaming OC RTX 2080 (OC'd); mb: Gigabyte GA-Z170X-UD3; ram: 16 GB (2x8GB) 3000 G.Skill Ripjaws V; psu: EVGA 650BQ; storage: 500GB Samsung 850 evo, 2TB WD Black; case: Cooler Master HAF 912; cooling: Cooler Master Hyper 212 Evo, Lots of fans, Air!; display: 4k Samsung 42" TV, Asus MX259H 1080p audio: Schiit Audio Magni Amp w/ Audio Technica M50x
https://linustechtips.com/topic/941266-rx-480-fps-lag/#findComment-11474881
Reinstalled drivers, same problem
The only thing is, as soon as I open Taks Manager the FPS dramaticaly increases
5 hours ago, Konrad Kwasniewski said:
I would reinstall drivers and check the thermals on your card. I used to have similar issues with my RX480 but a driver reinstall and a bios flash has made my card run the way it should.
Alright I will try to update (flash) my bios
I already tried reinstaling drivers, and window or fullscreen mode doesen't make any difference, nor does VSync
https://linustechtips.com/topic/941266-rx-480-fps-lag/#findComment-11475799
