FreeNAS boot drive and UPS
I was looking at making a FreeNAS server and looking at a boot drive, they say you can use a USB stick. If the USB stick dies, will it lose or corrupt data on the main drive? If that is the case, is it a good idea to use redundant drives? If not redundant USB drive running in RAID 1?
Thank.
If the thumb drive dies it shouldn't hurt the drives. You can setup two thumb drives in RAID1 when initially setting up FreeNAS. If this is a serious concern for you you can do it.
Though it's always possible for something to go wrong with ZFS itself be it from sudden power failure, mis-configuration, or misuse of hardware.
Redundant PSU's are costly and aren't really worth it unless you have two independent power sources (two independent lines in or two UPS's) for cost efficiency buy a good quality desktop PSU and just one UPS in the event of mains power failure. (provided this isn't for a professional operation)
