Ethernet does not have valid ip configuration
I just built my first gaming computer useing a Ryzen 2600 and a x470 mobo. Windows 10 pro installed without any issues, but when I hooked the Ethernet cable it says no internet. The error is Ethernet does not have valid up configuration. Is this a software or hardware problem? Anyone got any ways to help fix this?
1 minute ago, Lurick said:
Did you install the ethernet drivers from the motherboard makers website?
^ Or the CD it came with.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Install the latest drivers for it first. You can find them on your motherboard's website.
If they're already installed, check if your NIC is set to get the address automatically.
Press Windows Key + R, type ncpa.cpl and click OK.
Right click on your ethernet adapter and select properties.
Select Internet Protocol Version 4 (TCP/IPv4)
Click Properties
Tick Obtain an IP address automatically
Tick Obtain DNS server address automatically
Click OK
Click OK.
If it's already set to that and not working, you can run the following commands in CMD (as admin) to reset it. You'll need to restart the PC after this:
netsh winsock reset
netsh int IP reset
1 minute ago, NotAnkit said:
One was already installed I am pretty sure, and I can’t get on the internet to download anything
You're on the internet somewhere if you're posting here. Download it on the device you're currently using, then transfer it across to your PC.
Things to check
Is the ethernet cable working, it might of broke???
Do you have the correct drivers???
is your router/similar set up as a DCHP Server to serve IPs???
check IP4 settings and maybe assign yourself a static IP through that
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
Windows can only account for so many network controllers. It may not be supported meaning Windows may have no driver for it. You should be able to get the driver off the CD that came with the motherboard. Beyond that you should download the most up to date version from the motherboard manufacturers website.
5 minutes ago, NotAnkit said:
once I download the drivers on a usb stick, what do I have to do on my conputer.
Most likely unzip them. Right click > Unzip and then run the installer (usually .exe or .msi)
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
