So i just built a 8700k on a z370 prime with a 212. Factory clock and everything only changed is XMP for ram at 3200. looking at temps. i sit right at 32-35C. which is not too bad being ambient temp is right around 28-30ish. go to get a factory spec cinebench test. instant to 80s plus sometimes hits 90s first test. all cores. Paste is arctic silver 5, was a dot normal size. any help here is greatly thanked . Gets me concerned on temps being too hot. i was looking to stick with air right now. Wasn't going to h2o yet.
thanks for looking. hope to fix this issue soon.
https://linustechtips.com/topic/937771-212-evo-issues/
the 212 Evo is not a great performing cooler for that CPU.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11443706
While the 212 evo isn't great it should manage better than 90C on a stock 8700k. What case do you have and what fan configuration?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11443714
@sazrocks it's a Fractal Design Define R6 case. Factory config. 2 in front as pull and one in back as a push, I was thinking I needed more as well. but as soon as the test stops. it goes back to 35ish in a second or two.
like this https://www.newegg.com/Product/Product.aspx?Item=N82E16811352078
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11443742
That still doesn't sound right. How fast is the CPU fan set to run?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11443749
Probably not enough mounting pressure, plus the motherboard giving way to much voltage (as they always do)
Desktop benching:
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11443768
Stock settings is the issue here. Your mobo is using suto-OC feature when CPU is running demanding tasks. You can disable that feature from mobo settings. Temps will most likely still be rather high, but you could set manual voltages to keep them low.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11445153
I hit 86c with a 360mm AIO under AIDA64 at 5.0GHz.  These chips are scorchers, even at stock speeds.  The 212EVO was launched when chips were cooler and slower, it's not what it was.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11445194
4 hours ago, 90redtsi said:
so i ended up getting a x72 kraken AIO and it is a total difference. Guess I have to go to water, because i didn't snatch the 8700k to under clock it.
Underclocking or even undervolting isn't the thing I'm talking about. If you look how voltages are while stress test is running, you understand what I mean. Intel has had this issue since Devils Canyon. 8700K is hot chip, there's no denying that. But you can run it at stock clocks with budget cooler and reasonable temps. Not overclocking, but not over 85C temps either.
Intels stock voltage is 1.1V. You will never see that voltage if mobo is set to use auto voltage. Mobo will control voltage and raise it to 1.29-1.37V when running heavy tasks. Those voltages are good for hefty OC and way over what you need for just stock clocks. So easy way to fix things is to disable any auto-OC feature and set manual voltages.
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11446839
For a matter of facts @LoGiCalDrm is right, this is an Asus motherboard and those have MCE enable by default meaning the i7 8700K is not boosting up to 4.3ghz but 4.7ghz which made temps so high.
One thing that keeps bothering me plenty though is how do people still buy the 212 Evo in 2018? when it has been replaced by the 212X years ago already which has a much improved fan and slightly better heatsink design.
Either was this is the ultimate best cooler to buy for the locked i7 8700 as I have proven mine locked at 4.4ghz 1.2v keeps within the 68Cº~70Cº on max loads while being virtually silent (thanks to the new fan too)... but for an unlocked CPU it is a waste of money to get one of these as they will fall short on the only reason you buy an unlocked CPU which is overclocking it.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11446900
1 hour ago, Princess Cadence said:
@LoGiCalDrm
212X has been more expensive for long time.  $10-20 more for very little improvement is usually where older takes it. Plus availability.
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11447052
what do you mean "Kind of"?
System specs:
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11448153
28 minutes ago, 90redtsi said:
like itll be doing fine. then the test, cinebench. Just locks up. can move mouse, can't click anything. but it like freezes. Then after like 5 seconds it will go back to the test only completed.
well the test uses all cores and threads to complete, so it's not bizarre that the system doesn't have resources available to run the desktop. If you've set cinebench priority to highest in task manager, that'll be why it seems like it freezes.
System specs:
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11448418
18 hours ago, 90redtsi said:
yeah like said. i just went with the x72. everything is fine now. having an issue of when doing a stress it kind of locks up the pc. any idea on that cause?
Two things to try. First is to drop XMP of RAM. Second is to increase pagefile. This sounds like RAM is maxing out.
https://linustechtips.com/topic/937771-212-evo-issues/#findComment-11450013
