How Hot Do the Heat Pipes of a CPU Cooler Get?
Solved by Lady Fitzgerald,
I found the temperature of the heat shrinks I have is 110C (it shrinks at 121C) so I'm goiing to pull the cable, then strip the sleeving and replace it with a length of heat shrink. Problem solved.
Thanks for the help, you all!
Featured Topics
rb19 ·
Posted in Graphics Cards0 -
2
yepnew ·
Posted in New Builds and Planning1 -
TukangKopi ·
Posted in Networking2 -
2
12
17
