need some help Please!!!!
Benichi
I had this tv Vizio 46 inch plasma older. it has red vertical lines on the screan they do start to disapear if left on long enough. I pulled the back oof and checked cables and stuff. I did fined these 4 capasitors that look blown but not sure. pics below
post-50708-0-92335000-1388102707_thumb.j
dude, dont fuck around with capacitors in a TV lol send it back asap.
Also: If they really would be blown, your tv wouldnt work at all and it would smell like bad eggs.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
this tv is old jsut trying to fix it and was not sure if these are bad or not all of them are flat on top except for these 4
even old capacitors can give you a nice electric shock you'll not forget for a long time...
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
yeah I have change lots of them but never any this big with the top covered with plastic.  do you think they are bad
i think the whole tv is bad if it shows red lines.
Those capacitors specifially should be good since they dont repair themselves if left on long enough. lol
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
the lines do fade out if you watch tv long enough
look up aussie50 on youtube he has fixed heaps of tvs that have problems like this or bad caps etc maybe ask him or look at comments might tell u what is wrong.
Well. They probably are going but they aren't dead yet. The vertical lines are probably coming form the display board and not the High Voltage boards which is what your are looking at. If you can shows us a picture of the entire back. We might be able to see something.
ok one sec I will take some pics
ok I had to edit the first post to add the pics look at the top again lol
