Posted June 13, 2018 Hey guys. I will be playing Cs go and pubg. I wonder if sacrificing the cherry switches for rgb is worth it. Sounds like a stupid question but I really need help on this one. Romer g vs cherry mx blue? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 They're just keys. It's not a sacrifice. Get what ever looks good Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 Author Just now, tp95112 said: They're just keys. It's not a sacrifice. Get what ever looks good I've heard that romer g is good for gaming. Maybe I'm gonna go for the pro or wait for months and get a hyperx elite rgb one. Thanksss Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 Just now, Zzzzz69 said: I've heard that romer g is good for gaming. Maybe I'm gonna go for the pro or wait for months and get a hyperx elite rgb one. Thanksss There is no such thing as gaming keys. Its preference. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 Author 2 minutes ago, tp95112 said: There is no such thing as gaming keys. Its preference. Alright. Thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 1 minute ago, Zzzzz69 said: Alright. Thanks No problem. if you can try out the keys before buying it definitely do it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 Author 3 minutes ago, tp95112 said: No problem. if you can try out the keys before buying it definitely do it. Suresure. I already tried the romer g on a g413 and it does the job already. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 13, 2018 Author 1 minute ago, Pangea2017 said: Check if you can play on mx blues at a local store. I use mx blues for writing and a second keyboard for gaming (mx black). Ooooh. Alright. I will check the perfect keyswitches for me ? Damn you some rich boi Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
