I want to upgrade the HDD in my laptop to an 250GB SATA SSD. I already checked out the Crucial MX500 and the PNY CS900. But I would like to get some advice. I'm not interested in an more expensive and faster SSD since the laptop is only my secondary PC.
Thanks!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/936952-need-help-choosing-an-ssd/
Thanks!
Crucial has always been my go-to company for good SSDs.
I've had mixed results from PNY gear in the past.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Personally I've worked with Intel, ADATA, Samsung, Corsair, & HyperX SSDs for various projects. Can't say I've had many issues with any of them. Personal preference out of all the brands would have to be Samsung. For the capacities I bought they yielded the highest R/W performance.
At the end of the day though your best option is to read buyer reviews and go with the one that has the performance figures you're interested in.
Thanks!
My first choices when it comes to SSDs would be Samsung and Intel for their reliability. However, all will perform about the same in actual usage: FAST... especially compared to your prevous HDD.
Do not be much influenced by synthetic benchmarks. They are mostly good for marketing.
They are run at queue lengths of 32 or so to find the maximum sustainded i/o rates. But, in normal operations, we do things mostly one or two at a time so such readings are not a good predictor of your performance. In fact at low queue lengths, the response times of all current SSDs are amazingly similar.
However, if you are still having trouble deciding, this might help you a little bit:
http://ssd.userbenchmark.com/
