I'm building a pc for gaming and possibly a little bit of streaming. I have two monitors, one is 4k 60Hz and second one is 1080p 60Hz.
So I need help with the components choice. Are all the parts compatible? Is the CPU cooler enough for overclocking to about 4.7 GHz? Is the power supply enough? Or anything else you see that wont work?
Also, I'm definitely not going to spend any more money on this, so if I upgrade some component something else has to downgrade.
Specs:
Case: Corsair 570x
GPU: MSI 1080ti gaming
CPU: i7 8700k
CPU coolerBe quiet dark rock 4
Ram: G.skill trident z 16gb 3200MHz
Motherboard: MSI Z370 gaming m5
SSD: Samsung 860 evo 500gb
Harddrive: 1tb
Power supply: Seasonic focus+ 650 gold
Case fans: 3 extra Corsair sp120 (6 total)
Thankful for advice :)
https://linustechtips.com/topic/935824-new-build-need-help-with-components/
Yes - Maybe ( It depends on CPU but cooler should be plenty-slicon lottery) - Yes - No
Magical Pineapples
On 09/06/2018 at 7:47 PM, Mywallethurts said:
Aren't all i7 8700k the same?
Not all. There are some chips that overclock amazingly, and some that are just plain crap. For a GPU, a 1070ti or a 1080ti will be great. The 1080 is beaten by an overclocked 1070ti, so don't buy one of those.
As for the CPU cooler. I am not sure if you are aware, but 8th gen or "Coffee Lake" CPU's run very hot, so AIO's are your best friend when you are overclocking. A 280mm AIO would be safe for up to 4.4 and 4.5, and a 360mm AIO for 4.7 and beyond.
hi.
