Cooling for a 8320
Go to solution Solved by deathjester,
But will I be able to OC with the Hyper 212 EVO?
Yup. Can do 4.5 on my hotter then hell Haswell and keep in thermals. It isn't as good as a NH-D14 though. On a NH d-14 I could do 4.6. Past that probably need dual rad water.
NH is also quieter if noise bothers you. If you are going for like 4.4-4.5 on a AMD? The evo is fine. If you want to push past that? NH. You are limited by a motherboard on AMD though, so unless you have a Asus/Gigabyte 990fx board? I would get the Evo.
Hey guys,
Just updated my rig with a 8320 and I'm pretty satisfied, but as we all know, the stock cooler just sucks. With a budget of roughly 50$ which cooler would you recommend? I'd eventually like to OC a little, so I'd enjoy one letting me do that. Is it worth looking into liquid cooling in that price range? Up until now, I've mostly seen the Hyper 212 EVO recommended.
Also, when my computer runs full load while gaming for an extended period of time, it has a tendency of crashing. Having only one screen, I haven't had a chance to monitor temps yet, but is it an educated guess to suspect my CPU being the culprit? My GPU is a gtx 660 and I've had it for a while in another build and it never caused me any problems.
Here is my current build:
https://linustechtips.com/topic/93525-cooling-for-a-8320/
cooling wise the stock cooler does a decent job but is just very loud. Id go with the 212 evo too and save some money since its already pretty good.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256572
NHD14?
NHU14?
to say something different than the 212 evo
The have the D on boxing sale at ncix or whatever for 59 bucks? Shoot man....wish I picked up one for that price lol.
http://us.ncix.com/products/?sku=47090&promoid=1051
If you got 60 bucks and that fits in your case? HELL YEAH BUY THAT @#%@.
If you got 30? Evo 212 is best on a budget.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256583
NHD14?
NHU14?
YES nh-d14 for sureeee
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256603
On Budget: HyperEVO212
Not on budget: Something like a Noctua NHD14 or Dark rock pro 2
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256610
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256747
A 212 EVO will not improve your temperatures over the stock cooler, only improve the noise levels so I definitely don't recommend it if you want to overclock.
Get an NZXT Havik 140, it's only between a 1-2c warmer than an NH-D14 but cheaper and smaller.
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256791
Huh? A evo dropped load temps on my stock cooler by 25C. The AMD stock cooler is as bad. It might not be 25 C since the Haswell runs hot as hell, but a evo or any 120mm single tower fan (they are all about the same, the evo fan just pushes a lot of air for a good price) will perform way better then the stock fan.
If you didn't see a difference from a stock cooler to a 120mm fan cooler, you either had a broken heatpipe or the cooler wasn't making contact with the CPU.
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/61275-noctua-nh-u14s-nh-u12s-cpu-coolers-review-7.html
All 120mm single tower fans are about the same. Even the uber expensive Noctua single tower 120mm isn't any better then a Evo 212 and they are as good as the cheaper single rad water coolers.
A NH-D14? Yeah better. Dual rad water? Even better. The only reason the Noctua U-12s scores better then a evo is probably the thermal grease. Noctua grease is fantastic.
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1256850
I've built an FX 8350 system for one of my friends with a Hyper 212 EVO, the idle temperatures did improve, so did the noise but the load temperatures did not show any tangible improvements, especially after overclocking.
We were able to overclock all 8 cores to 4.3Ghz on the stock cooler and still have a prime95 stable system, the EVO did not give us any additional overclocking headroom.
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1257049
You installed it wrong or had a broken heat pipe. I have had Noctua's (and that is as expensive as you can go on air) with broken heat pipes. The delivery service probably kicked it around like Ace Ventura. :(
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1257078
No the cooler was in perfect working order, we didn't order it online either, we picked it up ourselves from a local shop.
We know it was working perfectly because it showed improvements over a Cooler Master Hyper TX3 that we were previously using.
https://linustechtips.com/topic/93525-cooling-for-a-8320/#findComment-1257098
