Should look great. I'd consider waiting for the Evolv X though since it will have integrated RGBs in the front panel along with better airflow. It will be out in August at a price of $199.99.
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419437
I already had the Evolv =\
CPU: AMD Ryzen 7 2700X
GPU: ASUS Strix Radeon RX Vega 56 OC
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419443
16 minutes ago, jesseo2003 said:
What do you think? I think it should look pretty sexy.
https://pcpartpicker.com/list/2vkDjy
I already had the 1800X and I know I have a X470 mobo picked and I plan on upgrading to 2800X once it comes out later this year.
Build something like this and save a few bucks.....
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  ($309.88 @ Amazon)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($94.99 @ Newegg)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($129.99 @ Newegg)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($169.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($72.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.19 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC2 Video Card  ($754.98 @ Newegg)
Case: NZXT - H440 (Matte Black/Red) ATX Mid Tower Case  ($79.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($127.98 @ Trusted Tech Team)
Case Fan: Cooler Master - MasterFan Pro 120 Air Balance RGB (3 pack) w/RGB Controller 42.7 CFM  120mm Fans  ($39.99 @ Newegg Business)
Total: $1919.76
Generated by PCPartPicker 2018-06-07 00:19 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419450
i'd avoid the G3 for now and get a focus plus gold or RMx instead, i'd get 3 phanteks halos RGB frames to use with the existing fans.
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419472
Don't waste your money lol, wait until Ryzen 3000 in 2019, the 2000 series isn't a major upgrade over Ryzen gen 1 with the same core counts.
And don't pay that much for a 1080ti...
just live with like a GTX 1070 ti and you should be alright
You should also buy a case that actually has airflow, like a masterbox 5 black
And you don't need to buy windows, you can install it for free without a key straight from microsoft
$269 for 16GBs of RAM?!?!
Wouldn't waste money on fancy PSU cables or RGB, buy those new noctua fans, far more useful than RGB
What's your monitor set up? Resolution/refresh rate?
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419495
There are rumors of 10 or 12 core 2800X coming out depending on how the 9700k looks. If 2800X is 10 or 12 core I would consider it a go. If its 8 core 4.2 or 4.3 I would probably hold off. 4.6-5.0GHz 8 core I would consider it.
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419499
It's very likely not happening until Ryzen 3000, because they would have to move to a 6 core per CCX design to hit 12 cores on the desktop, and there will likely just be newer better chipset boards with it as well, X570 most likely
I also edited the post a ton, reposted below
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419504
  Reveal hidden contents
I already have a $30 Win 10 Pro copy from G2A back in the day. Also, I already have a 1080 Ti that I kept when I was doing mining and sold my other 1080 Ti's. I also already have a bunch of noctua fans including the chromax series but want LL120's. Money isn't really a problem to be honest. I care more so about aesthetic and how it will look and RGB goodness. lol
I have a DELL 27" G-sync 144hz  1440p 1 ms response
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419509
11 minutes ago, jesseo2003 said:
nevermind half of that then, should probably still buy a case that actually has airflow though...
The H500P Mesh has giant RGB fans and good airflow
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419624
Why the G3? Fails OPP and OTP
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419633
That rumor is false. More cores on Ryzen will come in 2019, if they bring more cores to Desktop. (We know more are coming for Server. Desktop isn't known yet.)
I'd honestly go for the 2600X, then upgrade to a Ryzen 3rd Gen next year. (Though, in many ways, performance uplift isn't going to be huge. Better clocks and 5-15% IPC?)
https://linustechtips.com/topic/935049-ryzen-build/#findComment-11419699
