Cleaning new radiator and cpu block?
Solved by sky_shark_101,
I have used Mayhems Blitz for cleaning a loop and never had any problems you can find it here https://www.mayhems.net/collections/cleaning/products/mayhems-blitz-kit. This is what I used when I had the same problem as you with VUE. They are UK based but I believe they ship internationally and/or have suppliers in the US. If you are in the US Primochill do a similar thing called sysprep.
As for your GPU block I would suggest taking it apart and using a toothbrush and warm water. If you watch Linus' video on cleaning his desk loop that might give you an insight. Also jayz2cents has done several videos that show him cleaning CPU and GPU blocks.
