Is this a new build? Upgrade to existing?
That PSU is literal junk. I wouldn't touch it with a 10 foot pole and a fireproof suit on.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
6 minutes ago, junzhi2002 said:
I am planning to build a desktop for generally purpose (gaming, video encode / decode, web browsing etc... [for my cousin]) I use AMD FX-8300 with Radeon RX 550 GPU and 16GB RAM. Is these ok for $500 US budget?
https://pcpartpicker.com/list/xpXDZR
This entire build needs a lot of work.
1) I'm assuming very light gaming?
2) Do you have a case already?
Not sure if you have a HDD already to re-use or a case so I added an SSD and Case to the build.
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($158.00 @ Amazon)
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard  ($64.99 @ Amazon)
Memory: Patriot - Signature Line 8GB (2 x 4GB) DDR4-2666 Memory  ($82.99 @ Newegg)
Storage: Toshiba - OCZ TR200 240GB 2.5" Solid State Drive  ($57.89 @ OutletPC)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Amazon)
Monitor: HP - 22cwa 21.5" 1920x1080 60Hz Monitor  ($89.99 @ Amazon)
Total: $523.84
Generated by PCPartPicker 2018-06-03 09:36 EDT-0400
Prior Build Log/PC:
Total: $523.84
That is a much better build than the fire hazard build from OP.
https://pcpartpicker.com/list/4PYygw
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  ($37.99 @ Amazon)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case  ($29.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Amazon)
Total: $433.35
Generated by PCPartPicker 2018-06-03 09:52 EDT-0400
https://pcpartpicker.com/list/v2zbLJ
The PSU is Just Dangerous also Limitinger yourself to such an old Platform isn't a good Idea. In My opinion the RX 550 2gb would be better because the RX 550 doesn't really benifit from 4gb
I would Go with Something similar to this https://pcpartpicker.com/list/CQgDZR
Total: $433.35
Total: $523.84
guys how about this troll pc?
ik its non-logical
https://pcpartpicker.com/list/D8Pygw
ik its non-logical
Stop spamming in the forums
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
-= Locked =-
Not entirely sure if your intent is to troll members but this thread is done.
 CHRISTIAN MEMBER
Guest
