So after I build my new PC I was installing Windows 8.1 OEM from the dvd on it. While it was installing the files I accidently hit the computer and the disk was scratched and the download stopped. The PC restarted and now it says no OS found. What can I do?
Do I have to clear the hard drive?
or
Get a new Windows disk/usb?
Team Carl
https://linustechtips.com/topic/93243-new-pc-os-problem/
or
Does the disc still work?
If not then I think the only way for you to get the ISO is to download it off Pirate bay, which would also require you to have another PC.
Also, you would have to reinstall Windows again which in doing that will require you to clear your HDD.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/93243-new-pc-os-problem/#findComment-1253812
Format the HDD on another pc and restart the process
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/93243-new-pc-os-problem/#findComment-1253817
Is it possible to clear the drive from the bios?
yah, your right, u can. although then again win formats the drive at the start of the install anyways.
EDIT: just realized this was my 100th post :D
https://linustechtips.com/topic/93243-new-pc-os-problem/#findComment-1253837
Congratulations:)
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/93243-new-pc-os-problem/#findComment-1253913
No need to pull your drive out and format it, the windows installation will do that automatically. You just need to worry about getting an installation medium to work so you can install it again. You can download the official ISO from here with you product key and then you can mount the ISO to a (at least 4gb) USB stick with rufus.
From there all you need to do is set boot affinity to your USB stick like you did your DVD drive and you're good to go :) Easy peasy!
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/93243-new-pc-os-problem/#findComment-1254020
