Help identifying M.2 slot Key type
Daan101
Alrighty so I want to upgrade my laptop's m.2 drive, but after doing some research I still am not confident enough in my ability to identify the key type slot.
So from what I can tell the slot has a M key on it and the SSD is a B&M key.
the SSD I am going to upgrade to would be a 960 evo which has a M key.
Could anyone confirm my findings?
sorry if this is the wrong section, and if you need any more info feel free to ask!
thanks in advance!
Looks like a regular m.2 slot, but that's just the form factor though. The problem however is that your ssd is a sata drive, and you want to upgrade to a nvme drive. You should check if your motherboard supports nvme drives, even though it fits, it might not work if it's not supported.
That is M key slot. You can identify it as pins from 59-67 are blocked. Pin numbers are labeled just under the slot.
The B key has pins 12-19 blocked.
But as @MkaiL said
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
The SSD pictured is an M.2 SATA, while the 960 EVO is an M.2 PCIe/NVME.
But as said, check the laptop specs to see if it supports NVME drives
so there appears to be a version of my laptop which has a NVMe drive, and I don't see them changing the motherboard just for a different config.
(on a side note I also learned my laptop has Nvidia optimus, still has shit battery life tho)
I shall buy the drive after my finals and install it,
Thanks for the help!!
