i7 920 terrible performance (not spreading load on all cores)
Go to solution Solved by Qwertic,
23 hours ago, JoostinOnline said:
Not really. It's about on par with a modern stock dual core when overclocked. You should struggle to run anything above low settings.
@Qwertic Try running a stress test with Intel Extreme Tuning Utility to see if the cores max out. Heaven Benchmark won't tell you anything, since it's GPU intensive.
FOR EVERYONE WHO MIGHT BE INTRESTED IN THIS FIX (not permanent) you might find a better way.
CHECK OUT THE VIDEO:
FOR ANYONE WHO IS INTRESTED IN A (not permanent) FIX.
HERE IT IS:
thank you for this i have ran cpu benchmarks with this cpu. Cinebench with overclock 3.6Ghz gets about 535 cb.  But ine every game my cpu seems to bottleneck (my ram is not full and not underclocked, my gpu runs at 50% and is a new gtx 1050ti) ssd and hdd is not the issue
THIS HAS BEEN FIXED: CHECK THE VIDEO
Hi my name is Joris and I have a real pain in the ass issue with my (older) gaming pc. After booting up my good old gaming rig from way back I noticed a hughe decrease in performance. I looked for usual errors like dust, drivers, temps, ram speed, bad overclock, old bios driver, old gpu driver... Then I found the issue. While playing games only one core is really working. Taskmenager and HWmonitor both show all cores (threads) active. But only on bar is filled up and when it hits 99% I get terrible lag. Some games are ofcours more cpu intensive then others (unturned ran at low settings around 150Fps, insurgency 40 whit heavy lagspikes, gta v 30 with terrible lag, warthunder runs good but not how it should. Remember these games are not single thread games.  (only 60 fos top with 1050 ti). I tried overclocking the cpu and that did improve the performance by a little. But I’m not able to fix this issue any on an idea? The cpu is just not spreading out its load to all of its cores.
Thank you!! @JoostinOnline@Majestic @kelvinhall05 @Pasi123 @Catsrules and @Agentx_007
HERE IT IS:
Btw sorry for my incorrect English. It is not my native language.
Want to see (you know with your own eys) the issue check out my yt channel
One: https://youtu.be/BilxsnkKsAo
Two: https://youtu.be/8C_ehCN59VI
This is my rig
mobo: Asus P6t (standard issue)
latest windows 10 update
cpu: i7 920 @2.66Ghz overclock 3.7 Ghz (35*C)
Ram: 2x 4GB ddr3 hyperX Fury clocked at 1066
124GB samsung ssd and 1TB seagate hdd
gpu: Gtx 1050ti (it is not bad gpu performance cause my 1080 has the same issue in this rig)
powersupply 700watt Weirdo brand (no idee what it is but it is not chinese)
Thx for reading this! I’m really out of idees right now is this a bad cpu or a bad mobo or just a system error/ software error. In case that it is the cpu could i upgrade to Xeon X5560? Or does my mobo not support that one?
Sounds like the game is just a single thread game, and doesn't take advantage of the other cores. I don't think anything is wrong with the computer.
You could run benchmarks and compare your results to other 17 920 results.
Probably something to do with Windows.
I wouldn't recommend upgrading to a Xeon X5560 because it only has 4c/8t. Some 6c/12t Xeon like X5660, X5670, X5675 etc. would be a lot better upgrade.
Intel Core i9-10900X, Asus TUF X299 Mark 1, 64GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, Asus GTX 1080 Strix, 500GB, 250GB & 120GB SSD, 2x 4TB & 2x 2TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Yea I have been thinkibg about that but 2months ago this game worked fine on the same machine and it this occures on all of my games. These games should run fine on this cpu. They are source engine games with multi core rendering. :/
Yeah I know right! But does my motherboard support the xeon. I mean the socket is the same 1366 but does the bios?
Most X58 motherboards support Xeons. You can find an official CPU support list by just Googling your motherboard.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
It should work on it but make sure you have the latest bios version.
Some other PC's:
A 920 is pretty old, so it's going to struggle with anything new. Let me explain multi-threading though. First off, it's difficult to code with that. You have to spread the processes out evenly so one core isn't overworked, and regularly check to make sure they're still in sync. I've only used it on one project. After spending a couple months trying to squash all the problems it introduced, I gave up and went back to a single thread. It wasn't quite as fast, but it was far more stable. Games that came out when dual cores were starting to be standard still only use one core, because it was difficult.
If your single core performance isn't great, and the workload isn't 100% balanced across all threads (which it never is), things will come to a hault while waiting for one of the cores to catch up. That's when some of the cores aren't going to have any work, and one will be at 100% usage.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
With anything new? Are you sure about that? :D Overclocked i7-920 should be still able to run new games without any problems.
Some other PC's:
You can try going to the Nvidia control panel and force "thread optimization". That can help a little. Other than that, the single-core being maxed is the renderthread. Your CPU can't handle all the drawcalls and it chokes. Overclocking and using framerate limiters are your only help.
That is why i’m so confused. How is my quad core i7 3.6Ghz struggling whit insurgency, cs:go!
Maybe you could try to reinstall Windows? It really shouldn't be maxing out 1 core in Heaven Benchmark or games.
Edit:
I just tried Heaven Benchmark with extreme preset on my Xeon X5670 + GTX 960
And CPU usage looks like that even though I have a lot of crap open on background.
Some other PC's:
The game used to work fine on the cpu 2 months ago. ?
How high is CPU temp at full load (8 threads) ?
What cooling ?
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
At idly about 35 and at load about max 60 ingame 40. it is a normal  cooler nothing special
Normal cooler (for me that's Intel BOX), can't do 60C load after OC.
Also, how high is your UnCore (NB Frequency in CPU-z) ?
Is PCI-e for GPU running at x16 2.0 speed ?
Pci-e is 16x dont know about 2.0 but it ran fine 2 monthes ago an no it is not intel cooler it is an old 8-heatpin cooler so it is a good cooler i don’t think the cpu is thermal throtteling would be able to see that ?
Edit:
I know right I reinstalled windows the moment i noticed this and other reasons but it didn’t change it intel support asus and geforce all say there products are working fine ( i knew i could’t count on those guyse)
Okay, you just proved you don't know anything about first gen i7's.
CPU-Z benchmark on my X5670 @ 4.32GHz 6c/12t, of course multi thread would be slower on a i7 with 4c/8t but it still wouldn't be bad.
And here is a video of my old i7-950 @ stock on a HP Z400. In cinebench that i7 is about on pair with a i5-6500 @ 3.2GHz in multicore
Some other PC's:
Wow fanboy chill I to am an lover of these cpu’s. Mine is just performinc terrible. It is okay to be mad. And I know that these Xeon cpu's have great performance believe me. And I'm really thinking of buying one myself. But this i7 920 is just performing terrible compared to my other first gen workstations.
If you have that little video could you show your cpu core ussage cause my gta only runs at one.
11 hours ago, Qwertic said:
Hi my name is Joris and I have a real pain in the ass issue with my (older) gaming pc. After booting up my good old gaming rig from way back I noticed a hughe decrease in performance. I looked for usual errors like dust, drivers, temps, ram speed, bad overclock, old bios driver, old gpu driver... Then I found the issue. While playing games only one core is really working. Taskmenager and HWmonitor both show all cores (threads) active. But only on bar is filled up and when it hits 99% I get terrible lag. Some games are ofcours more cpu intensive then others (unturned ran at low settings around 150Fps, insurgency 40 whit heavy lagspikes, warthunder runs good but not how it should (only 60 fos top with 1050 ti). I tried overclocking the cpu and that did improve the performance by a little. But I’m not able to fix this issue any on an idea? The cpu is just not spreading out its load to all of its cores.
This is my rig
But how can i be sure that this problem is caused by my cpu and not my other software/ hardware. If it is the cpu i'll be upgrading my system to a X5560. Does anyone have an idee?
HERE IT IS:
But if my quad core 3.6Ghz runs at on core why would a hexa core solve this issue. Remember i have this issue on every game (gta V included)
