https://www.razer.com/ca-en/gaming-laptops/razer-blade
Pros:
  • Got rid of Killer (bless the lord)
  • Gave us back soldered RAM (did NOT see this coming, someone smacked somebody on the Blade team)
  • Vapor chamber full cover heatsink (this is nice)
  • Webcam on TOP (copy this XPS15)
  • Finally stopped using the cancer HDT heatsinks
Cons:
  • Oh fucking dear lord Razer's history of QC makes me terrified of their heatsink construction
  • Could end up like the Razer Blade Pro vapor chamber disaster
  • The fins look tiny compared to what they want to put in
  • 1070 Max Q seems like a bad idea without a full LM mod (even then still looks like a terrible idea)
  • It is going to be power throttled as FUCK on the 1070 one, I can feel it already. 200w power adapter tells me they went the Aorus X5 MD way of saying fuck you power, smaller brick is better.
I think they hired a new team for the Blades because the I give you back DRAM slots is something the old Blade team would have never done.
@Eason85 @D2ultima
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/
you are using a razer blade from 2015? is that even safe to use? it is probably really rusty by now, if you cut yourself while shaving, you might catch tetanus. (jokes aside) i think... that the 1070 is there only and name, and is possibly downclocked to avoid power and thermal limits? not sure, but this sounds kinda fishy to me.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11366936
^^my thoughts too. Also mobo disaster
IMO it will have the same issues with the previous Blade 14. We'll wait for reviews
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11367071
Looks like a decent cooling solution. Let's see whether the mobo disaster still exist.
Desktop specs:
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11369161
Someone posted some test results of 1070 max-q model on a China forum. Here it is (it only shows contents from the original poster) *Not official
Check result of the stress test and hard drive test on pictures below. Note that the Samsung NVME driver might not have been installed, which leads to lower R/W performance.
Text version of stress test:
In gaming mode,  after 10 minutes of the test, AIDA64 stress FPU only + FurMark at the same time
The CPU keeps at under 90 ℃ while keeping at about 44-45 watts while the GPU core frequency is at ~911mhz and keeps at 84 ℃
The CPU reaches a maximum temperature at 100 ℃ so the temperature wall is not sure while there seems to be a temperature wall of GPU at 85 ℃. Don't know if it is adjustable by tools like Nvidia Inspector.
While huge heats burst out from dies, the keyboard still keeps rather cool, and much cooler than previous 14-inch models. Air flows into the chassis from not only the bottom but also the keyboard gaps, thus the WASD area would feel almost no heat (and a little bit cold!)
No noticeable coil whine, but the fans drive crazy on gaming mode. Loud and sharp as hell as described, but have not measured.
Edited by Nero Lee
The original author grants right to repost
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11369828
Hmm kinda mediocre IMO. Prime95 will surely murder the cooling system
Hope the mobo issue is solved
Desktop specs:
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11369837
30 minutes ago, ILiketoMobit said:
what's the mobo issue?
BIOS chip under heatsink, components blow etc
Desktop specs:
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11372681
Not optimistic knowing the poor quality of the last Blade.
Unless they pull a rabbit out of a hat with this one, I'll just stay away until user reviews come in
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/929607-razer-blade-15-thoughts/#findComment-11372705
